Replacement display (Replace A1989 -> A1706)
I am using A1989. Is it possible to replace it with a 1708 display?
Is it impossible because I have a T2 chip?
I want to use a new A1706 display
좋은 질문 입니까?
좋은 질문 입니까?
What you want and what works are very different!
No! You can’t use the older display used in either the two or four port 2016/17 models in the newer system. They are not compatible!
Here is the correct part for your system:
Presently there is no used displays available which would be cheaper.
해당 답변은 도움이 되었습니까?
how about A1707 2 port with A1706 4 port?
해당 답변은 도움이 되었습니까?
The A1706 system is a 13" and the A1707 is a 15" very different sizes!
And BTW both are four port systems.
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 789
