Trying to restore but won’t stops on unable to write filesystem
Hi guys,
Another issue
trying to restore Using 3utools but won’t it stops on unable to write filesystem
anyone have any help or advice.
Thanks in advance
좋은 질문 입니까?
Hi guys,
Another issue
Thanks in advance
좋은 질문 입니까?
If it cannot write to file system it would point to a faulty NAND.
해당 답변은 도움이 되었습니까?
I am getting the same error. What does that mean? And is there a way to fix the issue? I am trying to flash and retain users data because my iphone XS max got stuck in recovery mode with a memory full of pictures of my kids from the last few months..
Do you think I should try another usb cable? Or not ?
The person said it is a motherboard repair. Need experience for this. @kamijo08
@rakeshkay Yes rule out a parts issue before you can confirm faulty NAND you should try different cable and PC
@imicrosoldering thanks for the reply I’ve only just seen it will give it a go thanks
I had the same issue . I replaced the battery and charged it fully then flashed it with iTunes successfully without any problem. I guess battery is the culprit for me
해당 답변은 도움이 되었습니까?
ERROR: Unable to receive message from FDR 0B55C860 (-4). 0/2 bytes
iPhone x unable to mount file system
24 시간 전: 2
7일 전: 6
30일 전: 64
전체 시간: 6,731
