MacBook is super slow, kernel_task above 700% cpu, PMF006 and PPN001
My MacBook Pro (2018 15” Touch Bar) started being super slow suddenly and fans are running at max speed even on a cold start. I quit all running programs and checked the activity monitor, there is a kernel_task using between 700-1000% cpu. I shut down the computer and ran Apple Diagnostics, it gave me the following errors:
''There may be an issue with the System Management Controller (SMC). Reference Code: PFM006''
''There may be an issue with the power management system. Reference Code: PPN001''
I tried resetting SMC but no luck.
I read on this website that some people had that issue after a liquid damage, that reminded me I had a few drops of a liquid on the trackpad last week (literally a few drops).
So I decided to open the computer (first time it is opened, I had never touched anything inside) to look for any liquid damage on the computer. I followed a tutorial on this website to remove the trackpad, and I didn’t find any corrosion on the trackpad nor on the cable between the trackpad and the board. I checked the mother board for any corrosion too but I didn’t find anything either (I really doubt the liquid would have gone to the motherboard anyway, since it was literally a few drops on the bottom left side of the trackpad. Also, I haven’t unscrew the mother board and check on the other side for any liquid damage yet.
So here I am. The computer turns on and load etc, it’s just super slow, fans are running at max speed and the kernel_task is always above 700% cpu…
Has anyone had this issue? Do you think I should unscrew the mother board and check under it even though I doubt the water would have gone so far? Should I replace the trackpad even if it seems to work properly? Are there other sensors I should check? (I believe this issue is due to some sensor not working properly)
Here is a screenshot of TG Pro:
Here is a screenshot of Macs Fan Control:
Here is a screenshot of iStats from the terminal:
I see some sensors with weird values with iStats but I’m not sure if they are really relevant since it shows negative values for cpu core 7 and 8 but I only have a 6-core cpu… Plus, TG Pro and Macs Fan Control seem to show normal temperatures.
Thank you for your help!
좋은 질문 입니까?
댓글 2개
Running slow with loud fans points to a sensors issue. Can you post all the sensors with abnormal values? ( this MacBook probably needs a microsoldering repair)
Platypus 의
@mronion64 I already posted all temperature sensors I found, are there more than that?
Also I went to an Apple certified center. They ran a diagnostic test and told me a sensor (soldered to the logic board) is failing, so I have to replace the logic board. They said it's gonna cost around $1000, so I'm not sure what I will do at this point.
Alex 의
