주요 콘텐츠로 건너뛰기
A2116 / 2019 / 3.6GHz 쿼드 코어 i3, 3.0GHz 6코어 i5 또는 3.2GHz 6코어 i7 프로세서. 2019년 3월 19일 출시.
Having problems upgrading i3 with i7 CPU
Hi,
I have a 2019 21.5” iMac i3 3.6 GHz I3-8100 with 8GB
I first upgraded the HDD to SDD which works perfectly
Next I upgraded the RAM from 8GB to 32GB and it too works perfectly.
Finally I bought a new CPU [Intel Core i7-8700 3.2 GHz] but it didn’t work.
I’ve already tried re-installing my old CPU [Intel Core i3-8100 3.6 Ghz] and that works just fine again.
What was the problem? And which CPU do I have to buy to upgrade my iMac.
Thank you for your attention.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Hi! I have the same issue. When I tried to upgrade the CPU from the same i3 8100 to the same i7 8700 the system won’t turn on. When I came back to the original i3 8100 everything was fine.
Is it possible to upgrade the base model’s CPU to anything?
I read something about micro-code in the iMac’s bios, but the same iMac has the configuration with the same i7 8700 cpu. It must be compatible!
Where’s the catch ?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
SERGIO GIRALDO 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 280
