How to Repair Nokia 5130 XpressMusic`s Music Player?
When I open the Music Player a message pops out and says not enough memory.
How can this be fixed? Pls. anyone?
좋은 질문 입니까?
좋은 질문 입니까?
this is the software problem. this will not solve even after reset . you have to flash it means upgrade or install same version on it. this will solve this issue. if you have a dongles (Mx-key, Zaf, Ufs, Infinty, ATF(Advanced turbo flasher) any one from this . download the same Rm-495 latest version from support site then flash it . if you are normal user then you can use the Nokia software updater (download from Nokia site free software) then connect the file it will atumactically download the latest version and it will flash it . then you are ready . thumbs up. note that battery must be fully charged .
해당 답변은 도움이 되었습니까?
+1 good answer.....
Bro This is a Software Problem Flash With This Version Nokia 5130 rm-495 v7.91
Mehak Mahoo, it is a good answer, but it is the same answer as the one from SIMRAN, except 4 month later. For that reason I moved it to his answer.
flash ic
what if there no update available for this device sofware or application updates
24 시간 전: 0
7일 전: 7
30일 전: 16
전체 시간: 43,402
댓글 9개
LMGTFY, It appears as if you need to flash your phone. Here is a site that will help you with backup files if you do not have a recent one. Check all the links. link 1 and here is link 2
oldturkey03 의
You upgrade your device memory
AmiteAnselme 의
This is an outdated issue, but I would still recommend you upgrade your storage, or you can use an SD card.
curt norval 의
how to update
R krishna 의
bhai jan nokia 5130 main player ka masla hy to kia kro jaldi btao plz
noman noma 의
댓글 4개 더보기
