주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
Screen replacement not working
Hi ….i have an iphone 6 plus A1522….the phone’s screen touch is not worked….so i decided to change the screen by myself (professional) ….i ordered a screen from an online shop….after the screen arrived i tried but its not working just the backlight with nothing showed up…and then i put my old screen and its worked ….so I thought the screen is faulty…..so I bought another screen from another online shop….but it also did the same…..i tried everything like restore , hard reset , etc. I also checked the lcd connector ……. Pls give me a solution to fix this issue ….pls
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
I think you have two problems here.
1.       An iPhone 6 plus with no touch equals “touch disease” This will be a board problem not the screen. A search on iPhone 6 plus touch disease will give you more information.
2.       If your old screen works and the two replacement ones don’t I would check the touch and LCD screen FPC connectors they might be bent. When connecting the old screen the flexes probably lined up but with the new screens the wouldn’t have and the 6 plus can be difficult to connect if you haven’t had experience. The connectors can bend if you try to connect them when they are not lined up.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Vimal JR 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 114
