주요 콘텐츠로 건너뛰기
13" 알루미늄 unibody, 2.0 또는 2.4 GHz Core 2 Duo 프로세서.
574 질문 전체 보기
Why does the MacBook Pro doesn't boot up? (after top case replacement)
Hi!
I have installed a new topcase on my Macbook Pro (a1278) mid 2012.
Before installing it, the computer worked fine without a keyboard (I would usually remove the battery and power it on with the magsafe cable, since the keyboard wasn’t working).
Then I replaced the topcase (with Keyboard, no trackpad) and now the computer doesn’t turn on.
I tried powering it on with the magsafe and even with the Logicboard’s power pads and nothing.
I have attached a picture in case anyone has any suggestions?
Thank you!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
This has been fixed after I put the rear/bottom case back on the MBP.
I assume I had a cable poorly connected and it seems that puttng everything together solved it!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
Your photo shows the battery is not plugged in.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Yes I know :) I was turning the computer on with the magsafe only
댓글 달기
귀하의 답변을 추가하세요
Manuel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 63
