주요 콘텐츠로 건너뛰기
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
301 질문 전체 보기
Brake lights stay on when tail lights turned on
My brake light stays on when the tail lights are turned on. I have taken. Out the the trailer lights hook up. Don't see any broken or loose connection. The brake lights do not come on when pedal depressed and the tail lights are off. I replaced fuses ( they were blowing and had a buzzing noise. Noise is gone)). Hazards.., blinker and back up lights work.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
The Brake pedal sensor is needing to be re calibrated with the body control module. You will need a OBD2 scanner. Cheapest one I found is the NT510 by Foxwell. I got one for 100 bucks on eBay, Mine has all GM products but it can hold six brands, each additional is 60.00 more.
I did this on my torrent, and several equinox, and it reads my Yukon. it;s a good unit and already paid for its self. It does all sorts of things but here is how you do your brake pedal thing.
turn the Key on without starting, the machine will come on, it will read your vin, ID your car. Nopw do this
Manual Selection->It will ID Your car, your configuration and Transmission, agree Yes-> Click Other-> Choose Control Modules->Body control module->Special functions->BPP sensor calibration. Now follow simple instructions that say DO NOT STEP ON THAT PEDAL. 20 seconds tops you will hear the switch in your BCM “CLICK” turn the key back to off , disconnect the OBD2 plug , your brakes work now. and so will everyone’s that you know that ever has this problem. Or you can sell it for more than you bought it for if you like. i am keeping mine.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Michael 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 186
