주요 콘텐츠로 건너뛰기
모델 M8407 / 550 또는 667 MHz G4 프로세서
28 질문 전체 보기
My hinge is super stiff on my TiBook G4 Onyx
Hello, I am new to the forums. I have an old TiBook G4 that I started using again after years of sitting in my closet. I used to use it a ton about 8 years ago I never remembered the hinge being that tight. Is there an easy fix, or do I need to do more extensive repair?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Carefully taking off the hinge covers (2 screws each) you can gain access the the hinge screws loosen them to see if the alignment is just off, retighten if not better you’ll need a cotton swab and some WD40 carefully spray the WD40 into the red cap to make a small puddle. dip the cotton swab into it (not too much!) and wipe the exposed clutch spring move the lid a few times and try a bit more oil it doesn’t take much!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
ClassiMacYT 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 10
전체 시간: 119
