주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
Diagnostic led #1 on, but #2, turns on then off.
Hi,
I have a mid 2011 a1312 imac 27” i5 processor.
Recently did a ssd upgrade for hybrid drive. Imac run smoothly and everything is fine. But after awhile my imac does not have any boot chime and is not turning on.
Took out the Lcd and checked the diagnostic led.
"LED 1 - Indicates that the trickle voltage from the power supply is detected by the main logic board. This LED will remain ON while the iMac is connected to the AC power. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power is disconnected or the power supply is faulty.
LED 2 - Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
LED 3 - Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
LED 4 - Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
The problem comes, my #1 led is on and bold. And when I press the power button, #2 led turns on for awhile, then turns off. And then turns on for a few seconds and off again.
Tried to check my psu, removed the connectors and then plug back in again. Imac turns on and works for a few days, then now the same issue surfaced again.
Would like to ask, if this an issue to the motherboard itself or psu. Because I can't seem to find info on #2 led turning on then off repeatedly. Looping and looping but not turning on.
Do advise.
Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개:
To clarify your system had a Fusion Drive setup?
Yes it's running on fusion drive setup. 1tb hdd and 128gb ssd
댓글 달기
답변 1개
You need to break the Fusion Drive set before you alter your system as it can mess up the systems settings. See if you can fix things by going into the Startup Disk preferences and select the correct boot drive.
Did you run the onboard diagnostics? Restart your system and press the D key.
이 답변이 도움이 되었나요?
점수 0
댓글 10개:
Hi, I am not booting into the system at all. Have did all the steps you recommended for the whole day now. And the diagnostic led #1 is still on. But #2 will turn on for awhile, then off. Then looping this cycle indefinitely.
Which prompts me to think it might be a hardware issue. Either a psu or motherboard itself.
No display, no boot chime, not booting up.
My wired mouse receives power, turns on for 3s and then turns off again. And this cycle repeats.
Sounds like your power supply has failed.
Is there anyway to determine whether its a psu that needs replacement or a short circuit on the motherboard issues? Any points where I can measure with a multimeter? Thanks
Because I would like to determine whether its definitely the psu that's damaged and needs replacement, or the motherboard is fried. Considering the psu on the imac is not really cheap.
댓글 5개 더보기
댓글 달기
답변을 추가하세요
GuangLong Ng 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 16
전체 시간: 392
