주요 콘텐츠로 건너뛰기
Apple의 iBook 노트북 라인은 소비자 및 교육 시장을 겨냥한 제품이었습니다. iBook 라인은 iBook G3 Clamshell, G3 12", G3 14", G4 12", 그리고 G4 14"로 구성되어 있습니다.
832 질문 전체 보기
Freezes after keyboard replacment
I installed a new keyboard in the 12 inch ibook, now when it is powered up the screen freezes. I took it apart to check and all steps followed found everything as ifixit showed. Could it be the keyboard or something I might have done?
Cindi
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 3개
Can you tell us why you replaced the keyboard? What was it doing before the replacement?
Please tell us which type of iBook you have. G3 or G4, etc.
Did you replace the keyboard because of a liquid spill on it ?
댓글 달기
답변 2개
선택된 답변
Hi! Do you have an Airport installed in this machine? The reason I'm asking is that I've often found that if the metal Airport antenna plug is left loose and dangling, and the memory shield is not installed, it can short out the computer by touching the memory or other components on the logic board. Probably an unlikely scenario in your case, but something to look out for.
I would also turn the computer upside down and shake it lightly, and see if you hear loose screws. Loose screws bouncing around inside the case can also short out the board. I've been sold many a "freezing" iBook only to discover the laptop was fine, but that there were loose screws inside causing it to freeze occasionally.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Try running the computer without the keyboard installed, and see if it boots up. The only things you have the potential to mess up by changing the keyboard, are the keyboard, the RAM, and The airport card. If you want, try re-seating the RAM
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
vidaloca828 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 873
