주요 콘텐츠로 건너뛰기
2018년 3월에 출시한 6세대 iPad. 32GB 및 128GB 저장 용량 옵션의 Wi-Fi 및 LTE로 제공합니다. 9.7" Retina 디스플레이 및 64-비트 A10 퓨전 칩이 특징입니다.
222 질문 전체 보기
iPad 6 will show charge indicator but will not charge
I recently repaired an iPad 6 LTE iPad for a customer and noticed the iPad was stuck on 33% when I plugged it back it and stayed at 33% even though the charge symbol was present. It was an Apple charger and works on my other devices. None of my other cords worked either. I have seen other articles about charging chips being bad or blown, and I wondered if any of you had run into the same problem and have a solution. Repair was fine. Everything went well, and everything works except the charging. I do believe the battery was good before the repair, and the iPad hadn’t been opened up before or banged up a whole lot. Charge port on it was also clean and undamaged. My battery isolator pick stayed in the whole time as well. I didn’t feel any resistance when I put the battery screw back in, but the only other possible cause I could think of was some sort of debris or other thing stopping the battery from being fully connected. Just looking for some insight(and hoping it’s not the chip). Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
If you already swapped out the charging cord and ports, the best thing may be to swap the battery for a known good one.
It sounds like the battery is losing its ability to hold a charge and may need to be replaced.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
It is possible. I am going to open it back up to make sure I didn’t damage anything and will check the battery in the process.
댓글 달기
귀하의 답변을 추가하세요
Alec Thompson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 44
