주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
3GS SIM card reader issues
i have 4 iPhone 3gs’s with this exact issue. i tried to put the board into another housing to sell, and it no longer will read sim cards correctly. when i insert a sim card, It says No SIM in the top left, but sometimes will have carrier settings and phone number show up in settings, but those take over a minute to show up.
if i power it off and back on with the sim card installed, it will say Searching… and continue to say that even if i remove the sim card.
They all used to read sim cards perfectly before i removed the boards, but no longer will in the new housing or when i put them back into the original housings.
There is no way i damaged all 4 of them when removing from the housings/putting into the new ones. doesn’t seem to be an issue with the 2 gold bars at the bottom of the reader or the 6 gold sim card contacts.
Also, the one i’ve been messing with will now say No service, then says no sim card installed about 15 seconds after i take it out, but won’t recognize the sim being re inserted until powered off again, then it just repeats.
if you have any ideas of what the issue possibly could be, or if you need more info or photos, please let me know. thank you
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
There arw 2 things you have to check first there is a small coper strip on the logic bord right down under that have to touch the metal frame of the backhousing (step 12 at the possition of the yellow square) :
iPhone 3GS Logic Board Replacement
and second check the simcardreader if the micro switch is working when simcard is inserted.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Looks like your first suggestion was the issue, most of them were bent up and didn’t fully make contact with the housing. Thanks!
댓글 달기
답변을 추가하세요
Donny 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 6
전체 시간: 560
