Hvac blend door actuator replacement
Where is the blend door actuator located
좋은 질문 입니까?
Im not sure on all years but on my 07 escape it is located in the back left (drivers side) quarter panel. To access it ,you need to pull the plastic cover pieces on the inside of your rear hatch. They are push pins so pull carefully with your hands working it from the edges. There are some very good videos on you tube specifically for this Good Luck
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 3
30일 전: 24
전체 시간: 174
