Gas Dryer not heating up, Pilot light not coming on at all.
The dryer turns on and the drum Spins, but doesn’t heat up. The pilot light is not coming on. We have cleaned the tube under drum and sensor but still nothing.
좋은 질문 입니까?
좋은 질문 입니까?
First thing to check is the ignitor
Igniter
The igniter uses heat to ignite the gas in the burner assembly. If the igniter is not working, the gas will not ignite, preventing the dryer from heating. To determine if the igniter has burned out, use a multimeter to test the igniter for continuity. If the igniter does not have continuity, replace it.
Part #
해당 답변은 도움이 되었습니까?
Thank you so much for your help. I didn’t even think about the Niner but I just tested it and it seems to be functioning. The multimer had a reading of 79
24 시간 전: 1
7일 전: 7
30일 전: 19
전체 시간: 651
