주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년 6월에 출시된 iPad Pro 10.5형 iPad는 2016년형 iPad Pro 9.7형을 대체합니다.
Press home to upgrade, but my home button is not working.
Hi guys.
This is my situation. First, I fix LCD screen on my self.
while doing repair, I unfortunately tear the home button(Touch ID) cable.
My LCD is perfectly repaired but home button is not working. so I was using assist touch instead of home button. (it was fine)
But After make IOS updates,
Press home to update make me crazy.
assist touch is not appeared.
I already connect to my Mac with cable, but didn’t recognize it.
and I already connect with to pc iTunes but didn’t recognize, too.
Are there any other way to skip the ‘press’ the home button or fix it?
Plz somebody help me…
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
i have a solution. when iTunes finish updating your software, it will prompt you to keep the phone plugged with USB, but you have to unplugg it and turn your iphone on again and than connect it to itunes and manage as a new iPhone.
댓글 달기
답변 2개
선택된 해법
You should be able to replace the button although you’ll lost touchID. You also might be able to send it to a microsoldering specialist that can fix the original home button.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Yes, you are right..
댓글 달기
가장 유용한 답변
There is a way to unlock an iDevice running iOS that has a broken home button and no access to Assistive Touch. Try the following:
  1. On your Lock Screen, swipe right.
  2. You should see the Search field at the top.
  3. Type Settings in the Search field.
  4. Your 'top hit' should be the Settings app. Tap on this.
  5. You should now get the Touch ID or Enter Passcode screen.
  6. Enter your passcode.
  7. You should now see your settings.
  8. Go to General -> Accessibility -> Assistive Touch and turn it on.
  9. Also, while your still in the Accessibility settings, scroll to and tap the Home Button setting
  10. Change the Click Speed and/or Rest Finger to Open settings to see if that also helps.
Good luck!
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I like your answer better than mine! How do we switch yours to the best answer?
댓글 달기
답변을 추가하세요
kyungbum 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 12
지난 30일: 36
전체 시간: 2,198
