Why doesn't my Asus memo pad 7 me176c detects any wifi network?
Hi,
Thanks in advance.
Update (02/08/2021)
Can you point where the WiFi antenna is located please?
좋은 질문 입니까?
Hi,
Thanks in advance.
좋은 질문 입니까?
Hi,
Does the tablet’s WiFi detect your home WiFi network if you use the tablet as close as possible to the router i.e. <15cm?
According to this supplier the Asus ME176C_GPS&WIFI_ANTENNA part number is 14007-01750000.
Looking at the part number from this supplier shows what it looks like. It seems that the antenna is housed in a plastic module.
Hopefully this may help you to locate it, as I cannot see it in any of the images shown in the ifixit Asus MeMO Pad 7 ME176C guides. Perhaps it is under the back cover?? If it is on the back cover then the WiFi chip should be on the motherboard close to where the antenna connects to the motherboard via the spring connectors as you would lose too much signal strength if it is a lot further away.
Unfortunately I cannot find an image for the other antenna part number (14007-01750100) shown in the parts list to check what it looks like in case it is a lot different.
해당 답변은 도움이 되었습니까?
Hi Jayeff,
Thank you for the quick response.
I read here https://wiki.archlinux.org/index.php/ASU...)) that they share the same antenna for both WiFi and bluetooth but still couldn't locate it in the unite after removing all the screws.
I wasn't able to remove the main board completely due to the main camera stripe that wasn't very accessable to reach and unplug.
Hi @Billie Joe pt
BT and WiFi use the same frequency (2.4HGz) so they will share the same antenna.
Does the BT work OK then?
If so then it is looking like a WIFI only problem which is unusual as a lot of the time they're in the same chip on the motherboard.
Did you try using it very close to the router, you didn't say? If it is not picking up the WiFi when you are virtually touching the router with the tablet then it is not an antenna problem but either a WiFi hardware or software problem.
Try starting the tablet in safe mode and check if it now detects any WiFi networks.
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 222
Was it dropped or damaged in any way?
Denise Williams 의
Not that I remember.
I was trying to see if the wifi antenna was unplugged but I haven't locate it on the inside of the tablet yet.
Billie Joe pt 의
Its.located on the back of the unit theres some pins attached. Check for damage and make sure its connected solid or you'll have issues . Chip is x86
Denise Williams 의
Is the chip x86 located on the motherboard or on the down side of the tablet near the speakers?
Billie Joe pt 의
