주요 콘텐츠로 건너뛰기
2018년 10월 26일 출시. Models A1984, A2105, A2106, A2108. GSM 또는 CDMA / eSIM, nano-SIM 또는 dual-SIM / 64, 128, 또는 256GB / 검정색, 흰색, 파란색, 노란색, 산호색, 또는 빨간색. ("iPhone 10 R"로 발음합니다.)
468 질문 전체 보기
Why is my new screen unresponsive?
Ok this is quite obscure and is definitely racking my brain.
I have a XR that I wanted to replace the screen on. I bought a donor phone that has a good condition original screen. When testing this donor screen on the phone it came on it works well and touch responsiveness is perfect.
However, after transferring this screen to the phone I want to fix the entire top half of the screen is completely unresponsive to touch. I reseated the connection multiple times but always the same issue.
When I transfer the screen back to the donor phone it works perfectly again.
This made me believe it might be an issue with the phone I want to fix and so I put the original cracked screen back on but the response on it is completely normal again.
Therefore I am completely puzzled as to what is causing this. It’s like two working things come together to make a broken thing.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 2개
선택된 답변
If anyone ever has this problem: Turns out XR screens are produced by different manufacturers LG and Sharp and the screen are not compatible on certain XR’s I guess. I was lucky in that my own XR had a screen that was compatible with the phone. And the donor screen was compatible with my phone. So I just swapped them.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hey, is there a way to find out which manufacturer produced my original display? I've already installed two new displays on my XR, and in both cases, only the upper third of the touchscreen is functioning.
댓글 달기
Get a magnifying glass and check the connectors on the phone and the screen. Then clean the connectors with a qtip and alcohol and a soft brush. Make surge connections seated. Did you try the cracked screen on the donor phone to see if it works on it?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Yeah this wasn’t it. Turns out XR screens are produced by different manufacturers LG and Sharp and the screen are not compatible on certain phones. I was lucky in that my own XR had a screen that was compatible with the phone. And the donor screen was compatible with my phone.
댓글 달기
귀하의 답변을 추가하세요
Simon Knopf 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 39
전체 시간: 1,154
