iPod wont take a charge, no power is being drawn from outlet.
I plugged my ipod in and there is no display, no charge symbol, nothing. It isnt drawing power from the outlet either.
좋은 질문 입니까?
좋은 질문 입니까?
Try a different charger and/or cable. If that doesn’t do it, with a device that old, it is likely the battery needing to be replaced. Next would be the power connector is broken. Outside of that, it could be bricked. Here’s to hoping it’s just a cable! :)
해당 답변은 도움이 되었습니까?
Sadly, i am pretty sure its not a cable issue. I switched to 3 other cables and nothing worked.:(
It may be bricked due to the fact it has been sitting in a drawer for like 1 and a half years
Good opportunity to crack that thing open and take a try on a battery replacement. Also be able to check the charging port to ensure it isn't damaged. Good luck, man.
Joe
CyberGI
Do you have a inline volt meter to verify it's not pulling power. It could possibly be the battery, it could also be the tristar ic which controls charging and data transfer in and out of the ipod. It could have a bad charging port and once the battery dies and it won't charge it can't turn on. You need to open it up and hook it up to a good battery or a dc power source to see if it will turn on and that will include soldering because the battery is soldered on. If it will turn on you should test and see if iTunes will recognize it. And use a tristar tester to verify it's ok. And you can use a volt meter to verify if it's charging. It comes down how much time and money you want to put into it. I would first open it up and check the battery with a volt meter and then plug in the charger and see if it is getting charging voltage. And go from there.
해당 답변은 도움이 되었습니까?
My wlectrical outlet has a little light when the usb is supplying power. I tried it with my phone that i now use, and the light switched on. when i plugged in my ipod, it didnt light up. I blew out the port, switched cords, nothing worked
I will try the itunes later today and see if that worked
24 시간 전: 1
7일 전: 1
30일 전: 8
전체 시간: 120
댓글 1개
Any suggestions on what to do next would be appreciated
Dylan Devries 의
