주요 콘텐츠로 건너뛰기
Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
51 질문 전체 보기
Surface only works when plugged in after battery replacement?
I did a full housing, screen, battery replacement for a Surface Pro 5
It turns on only when plugged in tried 2 batteries now still the same issue.
I tried force restarting it and doing a driver update still not working
My next thing to try would be desoldering circuit board off OEM battery and soldering it to After-market not sure if the risk of lighting the battery on fire is worth it.
Any Ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Factory Reset the device with new battery fixed the issue!
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Hey Mark,
A bit of a digress but - could you provide any help on replacing the battery for the surface pro 5 ? Have looked online but can’t find a resource. I am considering following the surface pro 4 tutorial on this website, but I’d like to hear how you have tackled it first.
thanks
My boss and I think you may have to remove the daughter board off the old battery to the new it must be programmed to the motherboard. We gave up on the repair requires soldering near the battery. It could as well just be a bad motherboard not sure.
댓글 달기
귀하의 답변을 추가하세요
Mark D Schlossman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 570
