주요 콘텐츠로 건너뛰기
A1708 / EMC 3071—2016년 11월 출시, 이 MacBook Pro 13”는 OLED Touch Bar를 소개합니다. 듀얼-코어 "Skylake" Intel Core i5 CPU 및 Thunderbolt 3 포트 4 개 포함.
239 질문 전체 보기
Lines across the bottom of screen
Theres a problem which started yestersay where there were lines at the bottom of on Macbook's screen. It forms like bottom of the screen of when it start. (If you don't understand you can look at the image) It also fades a little when I don't use it. (Like in the image) The mouse is still slightly visible when its moved toward the glitched area. The lines also flicker very slightly.
I think the cause of this was the Macbook overheated and brunt some display cable in the device. I have been using it for very, very long. It was also making air rushing noises.
If you could see whats going on and suggest a way to fix it I would be very grateful. Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
You’er not alone!
Gradiant dark shade in bottom of screen, doing video editing
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
For me it gone by it self maybe u can clean the fans and the macbook and let to cool for a while
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Damien 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 54
