Why is my phone not charging
My charging station inside my phone is not working how do I fix it
좋은 질문 입니까?
좋은 질문 입니까?
I know some things suggested here, will be a bit obvious at first, but let’s take it from the top.
Hope those steps help.
해당 답변은 도움이 되었습니까?
Mine just switched from getting a white light on top to the large charging icon coming on briefly. Hopefully it will charge. Even with a new Motorola charger I get the “phone charging slowly please use a Motorola charger” message.
Other than this, the G7 power generally lasts long.
해당 답변은 도움이 되었습니까?
I had a similar problem where my moto G7 would not charge unless turned off, what I did was look at all apps that I had installed recently and either uninstall them or force stop them to see if it might be a software issue. Then I tried lots of different cables, and lightly twisted them while they were inside. Eventually, one of them must have dislodged some kind of dust particle or piece of lint and then it worked again. I would recommend getting a small canister of compressed air to have to hand to help clean the charge port periodically. Also make sure that you have all software updates up to date, just incase it is a software issue.
해당 답변은 도움이 되었습니까?
Dealing with the same crap. I just recently made the developer functionality available by repeatedly hitting the build number section located in the "About the phone" heading in settings at the very bottom about 7-10 times but will have a notice of your progress and the amount needed. I selected " Keep the screen on when charging" the I downloaded the "Ampere" app at google play store, opened it up to run ( it shows wether the connection is good or if its n along with the mA amount but you can view its progress much easier and , ore confidently during the charging process. Ots been about 1½-2 hours now of non interrupted charging and went from 3% to 90%. So its not a complete solution or fix but accomplishes giving you peace pf mind and a charge phone. Almost forgot, after plugging in I rested the end of the connector (furthest end of connector plug piece from the end that goes into the phone)on top of something that about ⅜ high but on the same siface the phone is resting on to put a little added upwards pressure on the plug. Like the same direction if you where to lift the phone by grabbing the charging cord, that directional angle.
해당 답변은 도움이 되었습니까?
This is all too complicated for an 85 year old technophobe 😂
24 시간 전: 5
7일 전: 19
30일 전: 74
전체 시간: 11,619
