PSVita charges for a bit then stops
Hello everyone, I've been trying to fix this for weeks and now is the time to ask some experts.
I bought a used PSVita a month ago or so, the seller said everything was okay so I thought no problem.
When I first tried to power it on, it didn't so I figured it was discharged, so I put the charger on and the orange light was blinking, so far so good. After awhile the orange stopped blinking and I tried to power it on, it worked, everything was functional, screen, rear pad etc, there was an issue tho, the battery just charged enough to turn on so I put the charger again and it didn't charge while the PSVita was on, so I turned it off and did the same. The orange light once again turned on but instead of blinking, it was solid orange, but…just for 20/30 seconds or so, then it turned off, I connected the charger again and it charges again for a bit and then stops.
My thought solutions:
- Open the Vita and disconnect the battery for some minutes - Did this multiple times and only once I got results, I connected the battery again and put it charging right away, it would charge for a long time, I mean 5 hours plus and when I tried to turn it on, only had half battery, if I tried to keep charging it after turning it off, once again did the 20/30 sec charging then stops.
- Buying a new PSVita battery - The battery was full charged and the PSVita was working perfectly, I let it discharge before trying to charge but guess what, the battery wasn't the problem because the problem was the same.
- Connecting the charger cable to a 5V 2A charger - didn't work.
- Cleaning the inside motherboard, components and connectors - Did so with compressed air and cleaned every bit of dust, didn't work.
- Buying a new charger cable - The cable seems to have some missing pins and if I move it too much, it stops charging right away, the whole charger isn't original neither, I already ordered a new charger cable and I'm hoping it will work.
- The charging port is damaged - I really hope this isn't the issue because I don't have soldering skills.
Any kind of help and advice is welcome, I have a toolkit and professional formation in dealing with electronic components and opening etc, but anything dealing with soldering is not for me.
Thanks in advance.
좋은 질문 입니까?
Charger wasn't the problem I guess, problem still exists.
Francisco Melo 의
