주요 콘텐츠로 건너뛰기
Guides for the LTE version of the iPad Mini 4—model A1550. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
32 질문 전체 보기
Why is my iPad screen shaking and showing double images on and off?
Hello everyone,
I have had my iPad mini 4 for about 4.5 years and 1 week ago the screen started to shake and split into double images. I have not dropped it before and have not had any water damage to it before. It’s a precious item gifted by someone I love, and I do try my best to take care of it though I understand electronics can’t last forever.
I have rebooted/restarted/turn off the device and it worked temporarily until a few hours later and the shaking will come back again. The touch functions work fine, everything else works fine except for the display.
This happens 2-3 times a day and usually 1-3 hours after using. I mainly use the iPad to watch videos only, and the shaking/double images ranges between 20 mins to 2 hours, sometimes with black-lit screen in between, and after that it will be fine again. I’ve brought it to a shop to have a look at it as I suspected there was a fault with the LCD, and they mentioned that there was nothing wrong with the screen and that it is unlikely a problem with the motherboard? So they only did a ‘cleaning’ but the problem still persists. Should I insist for them to change the LCD?
I do appreciate anyone who can help me with this issue please, thank you.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
They would need to test it with another LCD. I believe they would have to test it for a day to confirm. I’d rather not have it fully installed without testing first in case of it not being the problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Zappiness 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 55
전체 시간: 1,438
