주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung's tenth-generation flagship "phablet," featuring its trademark S Pen stylus. Released August 2019.
How to fix the battery temperature sensor? Too cold to charge
The phone was completely charged in the morning then midday I tried to put it on the charger when I got in the car. It said its too cold to charge and it will stop charging the battery until it goes back to normal .. except the phone is not cold at all. Its sorta warm from me holding it. I’ve kept it on the charger since it doesnt necessarily use that much power to stay on without the battery being drained but the battery continous to deplete while plugged in. I’ve seen other posts on why it give that message but no clear way how to fix it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
you have 5 options on what it could be. it could be the battery, the charge port board, the flex cables from the charge board to the motherboard, the nfc/wireless charging part or the connectors on the motherboard itself from the charging plugs or battery.
also some have had luck pressing firmly below the right side of the rear camera , sometimes the connector comes unplugged and that will fix it. do a google search its fairly common.
이 답변이 도움이 되었나요?
점수 3
댓글 4개:
Thank you. This fixed mine!!!!
Wow. That worked for my S10e. Thanks so much.
I pushed real hard below the camera on my s105G and it started charging. My replacement phone was already here and set up but a backup is a good thing to have. Thanks for the suggestion
Thank you! It worked on my phone.
댓글 달기
I would start with replacing the battery. To my knowledge the only way to repair the sensor is to do some logic board work. however the battery may just be going bad causing confusing readings for the system. the battery output for the s10 plus should be about 5 volts. Start there.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I'd get a vibration and a charging pattern on my screen. I put some tape across the centermost terminal of my battery. Phone is charging fine.
댓글 달기
답변을 추가하세요
Alex 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 60
지난 30일: 192
전체 시간: 12,029
