주요 콘텐츠로 건너뛰기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1697 질문 전체 보기
No display after soldering new hdmi chip.
Hey there!
I'm having an issue with a ps4 with no display, I replaced the hdmi IC chip on the motherboard, and it still won't show any picture. Model is CUH-1216B, and the motherboard is SAC-001. Is it possible that it might be the APU fault (the light after switching on is white), or maybe one of the hdmi coils/filters (one of them seems to be different from the others, but continuity checks on all of them)????
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi!
Could be the APU, but most of the time the light will blink blue, or it turns off after the blue light came up for 2-4 seconds, so I think the APU should be good to go.
HDMI coils/filters could be faulty which is causing this, but you need to meassure it. You can also just replace them, as the price is not that expensive.
Also check the HDMI port, it could be the port it self too (perhaps corrosion or pins bent, or the damage isn’t visible at all..)
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
About that APU, it doesn't seem like it's the problem, since the light goes from blue to white and stays like that, I left it for some time and it didn't switch off or nothing, so it has to be working just fine.
I ordered bulk hdmi filters, I'm still waiting for them to arrive. Can I also use similar coils from ps3 I have laying around, they seem a bit bigger, but should fit just fine… II ddon't want to break anything though.
I also ordered HDMI port tester (with the leads to each connection) so I will check it with continuity mode just to confirm that the port is working, because it looks to be 100% fine, it's the newer gen of ps4, when I opened it there was no dust or nothing.. So it's basically brand new inside
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Yeah, I think you are right about the APU. I think it's fine and working good.
I think it will work, but wouldn't risk it.. They also sell different coils depending on the PS4 model. CUH-10XX uses the same as the CUH-11XX, but they sell different coils for the CUH-12XX (also different coils for the CUH-2XXX and 7XXX). Better to wait for the coils/filters that would fit for sure.
Cool, I think the port is fine too as there is no visible damage. But couldn't hurt to test it, just to be 100% sure (you never know without testing).
댓글 달기
귀하의 답변을 추가하세요
Greg 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 8
30일 전: 29
전체 시간: 2,730
