주요 콘텐츠로 건너뛰기
A1708/EMC 3164 — 2017년 6월 출시, 이 기본 레벨 MacBook Pro는 (OLED Touch Bar가 아닌) 기존의 function keys를 유지합니다.
563 질문 전체 보기
Coffee spill MacBook Pro 13” 2017
My dad spilled coffee on his Mac. The data is worth more than the machine so I’m trying to get it off.
The screen is black but everything else appears to work fine. It is responding to button presses as expected.
It is not connecting to an external display using a usb c to hdmi connector.
The attached image shows the internal lcd connector. Would I damage it if I scrubbed it with alcohol and a toothbruh to get rid of the corrosion
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
DO NOT ATTEMPT A DIY REPAIR ON THIS. SEND IT TO ROSSMAN REPAIR GROUP.
That LCD connector has a major design flaw in that apple put a high voltage power line next to a low voltage data line which can kill the cpu and you can kiss your data goodbye. Power it off and send it to Rossman. He has a youtube channel you can check out. Here’s what I’m talking about with the data and voltage line. https://www.youtube.com/watch?v=bUUZUcu0...
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
If the data is that important I would definitely agree with @hootonberg and send it in to a specialist. Rossman Reapir Group does great work and I enjoy watching his youtube channel. Great resource.
I managed to get it working with the external display. It’s all getting backed up then my dad will probably get a new company machine. I might try fix it myself but there’s no point paying now
댓글 달기
귀하의 답변을 추가하세요
Bruno Debattista 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 109
