주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1199 질문 전체 보기
Dropped my iPhone X. No cracks but display gone black.
I dropped my phone accidentally. NO CRACKS in glass and touch screen is working fine but DISPLAY gone BLACK. I’m receiving Notifications, calls and speakers are working fine.
what might be the problem?
Do you think my screen is damaged?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 2개
가장 유용한 답변
There could be a few causes, the most obvious being the OLED screen could have damage underneath the glass that is keeping the screen from powering on and in this case you would need a display replacement.
Another possibility is it could be software related have you tried to do the soft reset of the phone by tapping volume up then volume down and holding the power button until the phone power cycles? I have seen a few instances where this happens and does fix the problem.
The only next step that you could take would be opening up the phone and reconnecting the display connections to make sure nothing came loose if that doesn’t work then you definitely need a display replacement.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It sounds like you need a new screen.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Thriven Kumar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 10
7일 전: 42
30일 전: 144
전체 시간: 5,997
