주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1199 질문 전체 보기
Can I swap Sensor Flex Cable to test earpiece?
Hi everybody.
I recently bought an iPhone X with a broken earpiece speaker. I thought it would be an easy fix to solder a new earpiece speaker onto the flex cable until I saw that someone else already tried to do so. Since I don’t have a multimeter on hand I was wondering if I can take the earpiece flex cable with sensors from my own iPhone X and use it to test the other iPhone X, to see if it’s a board-level issue or a flex cable assembly issue. Will Face ID break on my own iPhone X or is it fine to use it to test the other iPhone?
Sorry for my bad English…
Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
You can use it to test it on the other phone and it won't hurt it. Unless you damage the cable. But you can put a complete cable with the earpiece speaker and proximity sensor but face Id won't work. But you can use the other one and it won't damage yours.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Anders 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 122
