주요 콘텐츠로 건너뛰기
Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
157 질문 전체 보기
The charging indicator blinks even with the correct battery.
I bought a second hand dsi ll (the japanese version) online, but it doesn’t come with the battery so after i bought the battery for it, the led indicator starts blinking even i with the correct model no. for the battery. So now im clueless what to do.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi!
From Nintendo
Note: If the orange recharge indicator light blinks while the system is plugged in and charging, then it is likely that the battery is not installed properly. Properly inserting the battery should resolve the issue.
If you have ensured that the battery is installed properly but the orange light still blinks, check to make sure that the battery is a licensed by Nintendo. The only licensed Nintendo DSi battery will have the model number TWL-003 (Nintendo DSi) or UTL-003 (Nintendo DSi XL) and will display Nintendo's logo.
If the battery does not have the model number TWL-003 or UTL-003 then it is likely not a licensed battery.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
The batteries that i have all have the UTL-003 on it and still can't turn on
Did you test with multiple batteries? And did you used another charger? How are the battery pins inside the console?
댓글 달기
귀하의 답변을 추가하세요
Amir Sulaiman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 68
