주요 콘텐츠로 건너뛰기
Released June 2014, identified by model number B051.
33 질문 전체 보기
Leather covering on my ear cushion is peeling off--do I replace it?
I’ve been having a slight problem lately where the leather covering the foam on the ear cushion is starting to peel out. I used to be able to wedge it back into place with my fingernail, but I think I’ll probably have to find a more permanent answer soon. Can I just glue it back into place, or is that bad for the earphones? Should I replace the whole ear pad?
Also, would the answer be different if it was just a Solo rather than Solo2? The headphones are actually Solo, but not the HD version or anything. I don’t think there’s really a huge difference between the two.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Here’s a video on how to replace them:
https://www.youtube.com/watch?v=CCzrrgwF...
Several companies make replacement pads.
Here’s cheap ones from Amazon
https://www.amazon.com/Replacement-Earpa...
Here are better ones:
https://wickedcushions.com/products/beat...
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
thanks, I'll try that out!
댓글 달기
Glue near audio equipment isn’t the best idea, if you can replace it it’s probably a good idea. I’m not an expert on beats headphones and there may be better advice so I’d wait to see any more advice from others.
Hope this helps, Nick
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Maya N 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 43
전체 시간: 8,499
