주요 콘텐츠로 건너뛰기
Samsung의 열 번째 주력 핸드폰, 2019년 3월 출시. Android 9.0 (Pie)와 함께 제공됩니다.
71 질문 전체 보기
How can I access my phone if the screen is broke?
I need to get my files off of my phone, but the screen is cracked (very fragile thing) and the screen isn’t showing up. So obviously I wont be able to press “allow” to let the computer interface with the phone storage. What can I do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
You could put the motherboard into another phone and extract the data and remove it. The only cost will be time and possibly a 80 cent adhesive strip to reseal the battery cover. Or you can put a new screen on it. You can buy a new screen for around 200 to 250 dollars with frame. And I would buy it with frame. You might also get a new battery cover because if you aren't good at taking these off they are easy to break. But the cover is less than 5 dollars. All you will need is a heat gun or a hair dryer a pair of tweezers, a plastic spugger and a mini Phillips screwdriver. Ifixit has videos and there are a lot more on YouTube. You can either keep the phone or sell it and buy something else.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Bobby John Ford 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 66
