주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1200 질문 전체 보기
iPhone X not charging after battery replacement
I successfully replaced my battery with ifixit battery. When i turned it on it was at around 50%. I drained the battery to 10% then tried charging it, i saw the charging icon then left it alone. I checked back on it after an hour and it’s still at 10%. I used an original ipad charger i bought from an apple store with the cable tha came with my iphone x. I also tried using my iphone 11 pro max charger and cable and still does the same. How do i fix this. Thanks in advance
Update (06/19/2020)
Fixed it! I guess I got a bad replacement battery, contacted ifixit and they sent me another one. Replaced it again and so far it works great
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 1개
Try the old battery and see if it works then. It's a possibility that you got a defective battery. You can also try unhooking the battery and letting it reset. There is a very small possibility that you have a bad tristar ic and it could stop it from charging.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Unfortunately, i have disposed of the battery. Now, i have tried unhooking the battery and hooked it back it in but it’s still not charging
Allan is correct, most likely your battery is defect.
댓글 달기
귀하의 답변을 추가하세요
William Chua 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 20
전체 시간: 2,485
