MacBook Air not charging
My MacBook Air (13-inch, Early 2015) has been charging fine until today. When i plug in the magsafe power adapter (i did clean it and the port) it only lights up dimly and green. The battery also says "Not Charging" and the computer entirely feeds on the power adapter. I've tried SMC and PRAM reset, and changing the duckhead adapter to the ones included when you buy the macbook but neither worked. I did the Apple Hardware Test and it said everything is normal. I tried charging it at 10% but it wasn't charging so i disconnected it and waited for the warning on 3% but it still didn't charge and the battery % isn't going down or up either when plugged.
I have tried another macbook air charger as well and the same issue is persisting. The difference is that through other charger my laptop will charge till 30% and then the adapter and charging connector ports heats so much that it stops chrging.
Also my charger is working fine in another laptop. I also got the DC board checked. Please let me with the same.
Battery Information:
Model Information:
Serial Number: D86640608QUF90KF9
Manufacturer: SMP
Device Name: bq20z451
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 511
Hardware Revision: 000a
Cell Revision: 1200
Charge Information:
Charge Remaining (mAh): 648
Fully Charged: No
Charging: No
Full Charge Capacity (mAh): 6018
Health Information:
Cycle Count: 513
Condition: Normal
Battery Installed: Yes
Amperage (mA): -2352
Voltage (mV): 7112
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 1
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 10
Wake on AC Change: No
Wake on Clamshell Open: Yes
Wake on LAN: No
AutoPowerOff Delay: 28800
AutoPowerOff Enabled: 1
DarkWakeBackgroundTasks: 0
Display Sleep Uses Dim: Yes
GPUSwitch: 2
Hibernate Mode: 3
High Standby Delay: 86400
PrioritizeNetworkReachabilityOverSleep: 0
Standby Battery Threshold: 50
Standby Delay: 10800
Standby Enabled: 1
Battery Power:
Display Sleep Timer (Minutes): 2
Current Power Source: Yes
GPUSwitch: 2
Hibernate Mode: 3
Reduce Brightness: Yes
Standby Enabled: 1
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: No
Charging: No
좋은 질문 입니까?
