주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1199 질문 전체 보기
Ripped Ambient Light Sensor Face ID
Hello, I was working on another iPhone today and for the first time I ripped a flex cable. I ripped the cable connecting the ambient light sensor to the proximity and flood illumination. I was sure I have lost face ID but after booting up everything is normal. Should I just place the ripped sensor back in and call it a day? I have microsoldering skills but not great with flex cables and traces. I know that Apple disables the sensor when you replace the screen but I was just removing it to clean the glass underneath.
PS. I usually use heat to take the whole sensor assembly and plastic holder out but this time I didn’t need to transfer it over to a new screen so I tried to just pinch and remove the sensor. Noob mistake
Thanks for any help
I have included an image with a red line showing where the flex got torn.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
The only option you have is solder the cable back together, put a new sensor assembly in it and lose face Id or take it to apple and have them repair it and program in a new sensor. They may try to swap out the phone if you go that route so back it up.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for the reply. I have decided to just put the sensor back in without soldering it. I can't afford to lose face ID and having look at the ripped part its too close to the flood illuminator. I could damage that during soldering and then face ID would be dead. Everything works just not the automatic brightness control which I guess is better than having no face ID. Thanks for the comment though I appreciate it
댓글 달기
Just transfer over the original ambient light sensor to a new flex cable
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
How would that work? The are one piece from the looks of it.
댓글 달기
귀하의 답변을 추가하세요
Tom 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 57
전체 시간: 4,321
