주요 콘텐츠로 건너뛰기
2018년 3월에 출시한 6세대 iPad. 32GB 및 128GB 저장 용량 옵션의 Wi-Fi 및 LTE로 제공합니다. 9.7" Retina 디스플레이 및 64-비트 A10 퓨전 칩이 특징입니다.
222 질문 전체 보기
Why did the touch/digitizer function randomly stop working?
Customer brought in an iPad 6 (A1893)
The digitizer no longer functions at any capacity.
It is a company iPad, so it is in pristine condition.
Factory resetting device hasn’t worked.
I removed the screen- unsurprisingly, an OEM lens.
No signs of liquid exposure internally- again, pristine.
No visible connector obstructions.
I have tried TWO replacement digitizers to no success.
Board issue?
maybe its the touch disease curse of Apple 6th generation products?? /s
Any further insight would be greatly appreciated.
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi Steve B,
Hold down the circular Home button and the On/Off (Sleep/Wake) button at the same time for around 10 seconds. This will restart the device and should restore the screen to full working order.
Hope this helps,
Sincerely, Onlaf
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
thanks for the response Onlaf. attempting the soft reset, you speak of, was something we’ve tried from the beginning. we just received our third screen assembly(from varying vendors, at that) still no success in regards to the digitizer function yet the LCD has functioned fine with each replacement we’ve tried. the flex connectors visibly appear fine. even the solder connection on the board side looks fine. i’m assuming an underlying board issue but just throwing it out to the community to ensure there isn’t another approach i could take in resolving this .
thanks again,
Steve
댓글 달기
귀하의 답변을 추가하세요
Steve B 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 16
전체 시간: 61
