주요 콘텐츠로 건너뛰기
모델 A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 질문 전체 보기
Converting dead iMac to a display: can I use the speakers somehow?
So after trying many times to repair my 2011 iMac, I gave up and now I’m going to convert it to a monitor. I have that part solved — is there anyway to use the speakers? IF so, I can use this as a monitor for my mini.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 4개
가장 유용한 답변
Did you use this Driver Board?
https://www.ebay.com/p/12015167280
I have an empty chassis of the iMAC EMC 2429 except for Left/right speakers.
I installed the Driver Board kit and hooked everything up and it now works as a monitor via HDMI.
I notice the Driver Board has Speaker Output and what looks like a 3.5mm connector for AUDIO.
HOW DID YOU CONNECT THE INTERNAL IMAC SPEAKERS TO THIS DRIVER BOARD??
Update (06/21/2020)
btw, How did you Power the Driver Board,
I used a 12V/5A supply and notice this Power Supply gets pretty HOT.
I also noticed the LCD display itself also gets WARM…I assume this is normal.
Update (06/21/2020)
I notice the Left Speaker has a 5 pin connector
I notice the Right Speaker has a 4 pin connector
Update (06/21/2020)
Speaker Connector PINOUTs for Logic Board 820-2828
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Yes you can, and yes, it can be connected to a mac mini.
해당 답변은 도움이 되었습니까?
점수 0
댓글 5개:
@ranger1509 - How about expanding your answer with the details on how to do it.
Here is a guide to hooking up the monitor the the inputs, https://www.youtube.com/watch?v=gwzOVysJ...
You can remove all the internals that are no longer needed and insert the new components as for the speakers you can hook them up via audio controller
@ranger1509 - Thats better! But the speakers will need an amp.
If you are really dedicated you can cut out the old io, weld in a new piece of aluminum on and sand it first to get it flush with the rest, then with 2000 grit to
get the same finish, cut out new io holes, insert the new io
Thank you! Will watch the video and go from there. Thanks again!
댓글 달기
I notice the LCD brightness is low.
Why does PWM signal go from 3V to 0V when you turn LCD on??
I checked the voltages on both the Original Apple Backlight Inverter board and the new Chinese Backlight Inverter board.
Chinese INVERTER BOARD
LCD on
pin 1 11.45V
pin 2 11.45V
pin 3 4.53V (on/off) EN
pin 4 0V (pwm)
pin 5 GND
pin 6 GND
Chinese Inverter board
LCD off
pin 1 12.18V
pin 2 12.18V
pin 3 0V (on/off) EN
pin 4 3.0V (pwm)
pin 5 GND
pin 6 GND
APPLE INVERTER BOARD
LCD on
pin 1 3.25V (on/off) EN
pin 2 12V
pin 3 2.88V pwm
pin 4 GND
pin 5 12V
pin 6 GND
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I found the attached "Current Adjustment Guide" on alibaba
my Backlight Inverter Board has the following
weld on RC3,RC4,RC5,RC6,RC7
NO weld on RC1,RC2
R10 has 1R00 resistor
R11 has 2R00 resistor
https://www.alibaba.com/product-detail/C...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Rick Eames 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 15
30일 전: 50
전체 시간: 1,878
