주요 콘텐츠로 건너뛰기
Model A1224 / Mid 2007 및 Early 2008 / 2, 2.4, 또는 2.66 GHz Core 2 Duo 프로세서
548 질문 전체 보기
no video on the screen 3 diagnostic led every on?
hi
i have one imac a 1224 and non video on the screen
The diagnostic led on the logic board are
1on, 2 on 3 on but there isn't install the video card
because the led 3 is every on
my logic board is dead?
please answare me
dear Silvano
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
LED Startup Sequence
LED #1 = Power available.
If no LED is visible:
• Verify AC source
• Verify known-good AC cable is connected
• Verify cable connection between AC inlet and power supply
• Verify cable connection between power supply and logic board
• Verify power supply
LED #1 + LED #2 = Power available, and system is powered on.
If second LED is not visible when power button is pressed:
• Verify power button connection to logic board
• Verify power button functionality
• Verify logic board
LED #1 + LED #2 + LED #3 = Power available, system is powered on, and video card found.
If third LED is not visible after power on:
• Verify that MXM video card is seated properly
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
Hook it up to an external monitor with the video card in and see what you get.
댓글 달기
hi
but on my logic board the led 3 is every on when i press the power button
but the video card isn't install?
thanks Silvano
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
so, you are saying that you do not have the videocard installed on the logic board and the third LED is coming on. then your logic board is possibly dead. if you install the video card, does LED 3 come on? do you see video?
댓글 달기
hi
if i install the video card on the logic board
the led 3 is on but there isn't the video on the screen.
dear Silvano
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
sorry for the delay. i would recommend replacing the logic baord at that point.
댓글 달기
귀하의 답변을 추가하세요
silvano 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 840
