주요 콘텐츠로 건너뛰기
모델명 A1707. 2017년 6월 출시, 이 MacBook Pro는 Kaby Lake 프로세서 최대 2.8 GHz 쿼드코어 Intel Core i7 프로세서와 Turbo Boost 최대 3.8 GHz를 사용합니다.
327 질문 전체 보기
Fan runs over full speed after battery replacement
Hello. I’ve replaced a battery and now the left fan starts to run at 134%¹ just after turning on mpb. The right fan is starting at very low speed, then it overclocks, so I think it works fine. But there is no any sensible lags on working, cpu temp is fine, only real issue is a fan noise.
I’ve tried to reset SMC and NVRAM by several times, nothing has helped.
¹ By osx-cpu-temp tool:
  • CPU: 50.9°
  • GPU: 51.7°
  • Left fan: 5028 RPM (133%)
  • Right fan: 0 RMP (0%)
While by Macs Fan Control app:
  • Left side (min/current/max): 2160 / 7191 / 5927 on AUTO (custom setting IS NOT CHANGING the speed)
  • Right side (min/current/max): 2000 / 2000 / 5489 on AUTO, custom setting works fine
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
Inspect the ribbon cable from the fan unit for damage as well as look at the ribbon cable connector and the matting connector on the logic board for damaged pins. also make sure you inserted the ribbon cable fully.
If you don’t see any damage then you’ll need to replace the fan assembly: MacBook Pro 15" Retina (Late 2016-2019) Left Fan
MacBook Pro 15" Retina (Late 2016-2019) Left Fan 이미지
상품
$29.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Anton 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 5
30일 전: 15
전체 시간: 1,304
