Damaged mode dial on EOS 7D
Hi I've got a mode dial that's damaged, i.e. the button is damaged but works. I need to replace it along with the top plate. Can I do this without dismantling the camera?
Thanks
좋은 질문 입니까?
Thanks
좋은 질문 입니까?
You need to peel up the plate with the modes on these. Once you do that then you usually remove a screw in the center to remove the dial. The main thing you MUST DO is put it in full auto mode as this makes installation easier. This has worked for me on the ELAN 7, I very much doubt that Canon changed much between then besides the plate being a full cover part now.
해당 답변은 도움이 되었습니까?
See the answer below, please.
The hole button came off, it broke, its not just the plate. I don't know how to fix it.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 7
30일 전: 17
전체 시간: 202
