주요 콘텐츠로 건너뛰기
Apple 워치 시리즈 2 는 2016년 9월 7일에 발표되었고 2016년 9월 16일에 출시되었습니다.
132 질문 전체 보기
Apple watch Series 2 - adding adhesive to force touch gasket
Planning to replace the screen as well as the force touch gasket.
I’ve read some reviews saying that adhesive on some force touch gaskets don’t stick the screen to the case really well. Will adding more adhesive to the top and bottom of the gasket allow the screen to still fit flushed to the case?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
The gasket is not intended to be ridged! It needs to flex as within it is a sensor so the watch knows it was touched.
I personally haven’t had any issues when I was fixing the watch (I don’t any more). The issue I’ve have seen is people not cleaning the surfaces properly as well as touching the gasket adhesive.
Any oils or dirt on the surfaces will cause the part not to adhere properly. Make sure you are using reagent grade solvents.
The other issue is an old gasket which is not properly sealed can have its adhesive dry out.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for your response! very helpful. Was wondering if it still keeps some of its water resistant capabilities?
댓글 달기
귀하의 답변을 추가하세요
Khanh Nguyen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 61
