주요 콘텐츠로 건너뛰기
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
101 질문 전체 보기
1 inch from left side not responding after installing new digitizer
i installed a new touch screen digitizer and for some reason about 1 inch from the left side of the screen there is no touch response at all is there a fix to this ? i bought a zentop digitizer for my a1822 ipad
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
This is my second screen that has had this issue my connectors look fine. Can it be the screens im getting are bad? Should i try the ifix it brand of digitizers?
댓글 달기
답변 1개
It sounds like you have a defective part.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
This is most likely the case. OP try reseating the digitiser connectors on the board and see if that helps.
The other thing to note is that there is a peel for the adhesive on the digitiser cable that sticks that cable to the glass like the original screen has.
댓글 달기
귀하의 답변을 추가하세요
pat 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 52
