iPhone 6 battery percentage stuck after replacement
Hi. I just replaced my old iPhone 6 battery with a new one because the old one kept shutting down and only had 50% battery health. I ordered a new one online for the iPhone 6 and the installation went well. The problem I ran into is that the battery percentage won’t increase after a few hours of charging. It was in 30% when i first tested the battery and it only decreased to 23% instead of actually increasing the charge. Is there any way to fix this?
좋은 질문 입니까?
댓글 4개
There is, my first concern is did you seat the battery connector in properly? Please make sure the connection between the battery and logic board is not dirty or is not making a proper connection. If you have made sure and have cleaned the connection and it is still giving you this issue? You may have bought a defective battery, that can happen. Contact the seller of the battery and make a return if he allows returns.
Richard Steed 의
I tried reseating it to no avail. How do I clean the connector?
Thad 의
You dip a tooth brush in isopropyl alcohol, I recommend 99 percent. If you have no isopropyl alcohol, then you can just clean with just a dry toothbrush. If that does not work, send the battery back to whoever you bought it from, it may be a faulty battery.
Richard Steed 의
Do I clean the connector of the battery or on the phone itself?
Thad 의
