What means Greasy yellow fluid in the valve cover air vacuum hose?
i have a 2006 nissan altima 2.5l SE. I was changing the starter motor. When a removed the vacuum hose between the valve cover and the intake was some greasy yellow fluid in the hose. I thinh oil mixed whit antifreeze? What that means? And how could i fixed?
좋은 질문 입니까?
댓글 4개
We need to see what it looks like, and where it is. Sounds like a head gasket issue since yellow usually points to that.
I took a shot in the dark to put an answer out, but I aimed in the direction with the best chances.
Nick 의
You can get a head gasket tester that can check if it has carbon monoxide in the cooling system to verify. You can also see if you have a cylinder missing which can tell you which cylinder has the leak.
Allan Barr 의
@barriphone It's almost certainly the head gaskets and other seals. Classic Nissan defect post Renault. Individual testing is redundant - even one leaking is still a leak.
The only individual test worth *doing* is a cylinder pressure test.
Nick 의
It will probably have a cylinder misfire code in it and what cylinder it is.
Allan Barr 의
