주요 콘텐츠로 건너뛰기
The JBL Flip 5 is a small portable Bluetooth speaker, released in August 2019. It offers an IPX7 rating for water resistance and up to 12 hour battery life. Model: TT
31 질문 전체 보기
JBL Flip 5 can only turn on and turn off
Hello, i’ve just putted my JBL Flip 5 to charge because it wasn’t fully charged.
After i wanted to use it, and it doesn’t work as it should, i can only turn it off and turn it on, i can’t even factory reset it
No lights and not detected by Bluetooth, when i’m charging or turning on. Only the typical sound of JBL when i turn it on/off.
Does someone have an idea?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
For the Hard reset did you turn your device on , hold the volume and play button at the same time until the speaker turns off. Once off turn the speaker back on, a blue light should flash on the Bluetooth button, and now it is ready to connect. The device you are connecting the speaker to, if it has already been connect go into Bluetooth setting and choose forget JLP Flip 5. Proceed by reconnecting the Bluetooth device to the speaker.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
H. C. 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 27
전체 시간: 604
