hover-1 Nomad static current (other side) fault,Phase circuit of motor
Right side has stopped working, app diagnostics shows static current (other side) fault and Phase circuit of motor fault. struggling to find how to get this sorted with manufacturer.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개:
I have the exact same problem! The Hover-1 App has a built in diagnostic function and it said I have 2 issues:
1 - Static Current (Battery Side) - Fault
2 - Phase Circuit of Motor - Fault
Any help you guys could give would be great. The customer service for Hover-1 is nearly non-existent. They just send a pre-written email that is of no help.
We have the same issue. In fact both of our Hover 1 Nomad's have now broken with the same fault codes.
I have a hoverboard reporting the same issues as OP:
•Static current (other side) fault and...
•Phase circuit of motor fault
I have continuity tested every lead & component i can, all 12 MOSFETs test good, both wheel motors are fine & their 6 Hall effect sensors read voltage as expected (tested with 5v applied to the board & wheel spun).
did anyone find a fix for this that doesnt involve returning under warranty or replacing all the internal PCB's?
댓글 달기
