주요 콘텐츠로 건너뛰기
2011년 하반기 모델, A1278 / 2.4 GHz i5 또는 2.8GHz i7 프로세서.
591 질문 전체 보기
MacBook Pro Built in Trackpad only working when plugged on charge
Hi Guys.
So My 2011 MBP has developed a fault where the trackpad works completely fine when plugged in using the power adapter. As soon as I disconnect the charger, the trackpad becomes very jittery and its practically un-usable!
I have replaced the battery since there was a message saying “Service battery soon“, but its made no difference.
Ive read on other forums where people have the reverse issue where it works on battery but not when plugged in. Any ideas what the issue could be?
My initial thoughts are some sort of grounding issue? I checked the connector for the battery and cleaned both sides ( Battery + Logic Board connectors ) but still having the same issue.
Can anyone help?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 4개
You'll need to see if something pops under the onboard diagnostics. Restart your system and press the D key to enter into diagnostics, let us know what the error messages are.
Reference: Mac startup key combinations
The only thing that popped up was "4xxx/6x40000005 <>oa" Battery
I presume this is due to the replacement battery which is not Genuine? The old Battery I replaced was an original Apple Battery that came installed in the MBP
mmm... Thats telling me the SMC line to the battery is not working.
Lets check the battery and the charging logic, install this gem of an App CoconutBattery with the MagSafe charger plugged in take a snapshot of the apps main window as well as the batteries info tab and post it here for us to see 기존 질문에 이미지 추가하기
I have added the images.. Any other info please ask. Cheers
댓글 달기
답변 1개
선택된 답변
Zap the NVRAM (or PRAM)
  1. Shut down your Mac.
  2. Press the power button, and as soon as you power up the laptop, hold down Command-Option-P-R.
  3. Keep holding down those keys for about 20 seconds. ...
  4. Then check the Startup Disk, Display, and Date & Time panes of System Preferences to make sure they're set the way you want them.
  5. Battery Calibration
  6. https://help.ifixit.com/article/265-batt...
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
I would add resetting SMC should be done How and when to reset your Mac’s PRAM and SMC
Wow, I can't believe the battery calibration worked!! Drained it fully from 100% overnight and charged it back to 100% this afternoon. trackpad working as it should now! Thanks so much :)
Glad I could help out ;-)
댓글 달기
귀하의 답변을 추가하세요
Ibrahim Hafiji 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 26
전체 시간: 1,450
