주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Vive는 HTC에서 Valve와 공동 개발하여 2016년 4월에 출시한 첫 번째 가상 현실(VR) 헤드셋입니다. 기기의 모델 번호는 NM80PJT100입니다.
How do I fix my tracking issues?
I’m having trouble identifying the tracking issue with my headset. The base stations are wall mounted securely and are placed in the correct positions to be able to see each other and the devices in the playing area (All reflective surfaces have also been covered and the base stations are connected via sync cable). Despite this, the headset will have tracking issues and sometimes “Rubber-band” (I.E. :The head will phase into the floor or rocket to the ceiling, or just have general tracking issues at random). My best guess is that there is an issue with the sensor’s in the headset because the controllers haven’t had that issue nearly as frequently as the headset has, the other guess is that there is something wrong with one or both of the base stations themselves. Any ideas to help fix this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
hi this is a common problem you can fix it using this guide
https://aiomobilestuff.com/htc-vive-trac...
의
댓글 달기
답변 2개
가장 유용한 답변
How large is the tracking area roughly? I have had the same problem and it seems that it was due to it being too large. It could also be if they are mounted too high like to the ceiling.
This was with a Oculus rift CV1 so I’m not sure how the HTC Vive would do as I’ve only set that up in small spaces.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Its a small tracking area. Roughly about 9 feet long and 5 feet wide of an area. I only stand in the middle of it due to the space I have available.
의
댓글 달기
Restart the Oculus Runtime Service .Reseat the Rift S cable .Swap PC USB-A ports .Disable USB power saving.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Duff 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 25
전체 시간: 997
