주요 콘텐츠로 건너뛰기
Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
124 질문 전체 보기
Power button is stuck
I have an apple watch series 4 that has the power button stuck pressed in. I had a protector cover on it that I never removed and it may have built up dirt and grime over time. I tried cleaning it around the edge of the button with a toothbrush and some water to no avail. When I connect the watch to the charger the apple icon comes on for a few seconds but then turns off due to the power button being stuck.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 7
댓글 달기
답변 3개
가장 유용한 답변
+1 for rinsing for a minute under warm water, which worked for me.
Context: after several days of swimming in salt and fresh water over the course of a week, after the last dip, the power button seemed to be stuck, going into Emergency SOS mode over and over again. After a reboot, the button was still stuck, so it could not boot: it would show the Apple logo for a few seconds then reboot again. Washing under warm water and clicking the button repeatedly fixed it.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
From others who have had this issue, it looks like you can carefully rinse it under warm (not hot) water from the tap. Maybe this would remove whatever is causing the stick?
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I had this exact same problem after using the SUP case. I found a local iPhone repair shop that was able to replace the power button and the clicking mechanism beneath it and the watch is like new again. Hopefully you can find someone willing to give it a shot!
해당 답변은 도움이 되었습니까?
점수 2
댓글 5개:
The same thing just happened to me with a Supcase. What did they charge for the repair.
Same here with the Supcase I wouldn’t recommend the case for that.
Same! SUPcase! Dang!
Same thing is happening to me. Also had in a SUP case.
The repair cost about 50 bucks I believe. Unfortunately maybe a year after that the battery started to die almost immediately and I had to get a new watch anyways.
댓글 달기
귀하의 답변을 추가하세요
Freddy Gomez 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 17
30일 전: 80
전체 시간: 15,916
