주요 콘텐츠로 건너뛰기
2.2, 2.4, 2.5, 또는 2.6 GHz Core 2 Duo 프로세서
20 질문 전체 보기
Trackpad not very responsive
Hi all,
Jan 2009 15" MBP has recently begun to develop an issue with the trackpad - it requires a VERY firm push to register a "click". Running SL, started prior to the install.
I tried a fresh install but same issue with the trackpad - much less responsive than previously.
We live a couple of hours away from the nearest Apple store, so hoping to get some advice before we have to go to the store (have Applecare as well, will phone in first before hitting the store.)
Thanks in advance for any ideas!
Shel
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 달기
답변 6개
가장 유용한 답변
I have an original MBP that did something like that... I put 2 stickey notes on the battery (spacing or insulation-not sure which) and reinstalled the battery. Works just fine now. Of course, mine is way out of warranty.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
You'd need to take the bottom case off. First inspect the battery to see if its swollen at all. If not, there should be a tri-wing screw on the underside of the trackpad. Adjusting this can affect the click, you'll have to experiment a bit. And you'll need a tri-wing screwdriver obviously.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Unfortunately, your issue appears to be hardware-related, not software. I would call AppleCare and setup a mail-in repair - you will save yourself a long drive (or two), and the Apple Store is probably going to send it to the depot instead of attempting an in-store repair.
I just sent in a display, it was turned around the same day - the depots appear to be pretty efficient currently...
The unibody models are constructed from the top case down, making the trackpad and keyboard the hardest parts to get to - complete opposite of the PowerBooks and earlier MacBook Pros.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
check here:
http://discussions.apple.com/thread.jspa...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I think that trackpad problems like this come with use of a laptop. The best fix would be checking the components under the click, the mechanism that registers your click. Apple might do this
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My trackpad scrolls fine, and does all the gestures but is not clicking what is the problem? any advice?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Shel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 6,636
